29641 Discussions
Compiler supports omp_set_num_threads() ?
stydofe1
I am using Intel composer XE 2011. I have some simple codes as below to test the function OMP_set_num_threads, the program freezes once entering the parallel region.
call OMP_set_num_threads(4)
!$omp parallel
print *, 'hello parallel'
!$omp end parallel
It works fine if I use clause instead.
!$omp parallel num_threads(4)
!$omp end parallel
What am I missing in using the routine OMP_set_num_threads?
The first version works for me. Is there more to the program you're using than what you showed here?
stydofe1
That is all codes in the program. Could the problem do anything with compiler options, systemenvironment variables?
I assume there is an END statement in there somewhere? I just compiled with /Qopenmp and ran it. Nothing special needed.
[plain]C:Projects>ifort /Qopenmp U85077.f90
Intel Visual Fortran Compiler XE for applications running on IA-32, Version 1
2.0.5.221 Build 20110719
Copyright (C) 1985-2011 Intel Corporation.  All rights reserved.
Microsoft  Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:U85077.exe
-subsystem:console
-nodefaultlib:libiompprof5mt.lib
-nodefaultlib:libiompprof5md.lib
-defaultlib:libiomp5md.lib
-nodefaultlib:vcomp.lib
-nodefaultlib:vcompd.lib
U85077.obj
C:Projects>u85077.exe
 hello parallel
 hello parallel
 hello parallel
 hello parallel
[/plain]
stydofe1
Below are the complete codes:
PROGRAM ACCTEST
external OMP_set_num_threads
!$omp parallel
!$omp end parallel
END
The commands for compile and link are:
ifort set_num_th.for /nologo /extend_source:132 /Qopenmp /iface:cvf /Fd"vc100.pdb" /threads /c
link /OUT:"para.exe" /INCREMENTAL:NO /NOLOGO /SUBSYSTEM:CONSOLE set_num_th.obj
Running the program will lead to an error of out of heap memory. The same problem happens on several machine.
Do you need more information to figure out the problem?
Interesting. It's the /iface:cvf that triggers the problem. If you remove that, it works. I'll have to ask the developers why this is. It is finding a STDCALL routine in the OpenMP library.
Do you need /iface:cvf?
jimdempseyatthecove
What happens if you keep /iface:cvf
Replace
with
USE omp_lib
Jim Dempsey
stydofe1
Yes, I need /iface:cvf, since in the programs I am trying to parallelize, some fortran codes are calling C programs or called by C programs.
That works, since it's the C mechanism OMP routine that is called then.
stydofe1
The problem is resolved byUSE OMP_LIB.
The developers tell me that they are removing the STDCALL entry points. USE OMP_LIB is the best approach whether or not you use /iface:CVF.
