Compiler won't load anymore
nvaneck
After exiting the compiler (12.5) this morning, it refused to let me immediately reload it. It just sticks with an empty framework and never gets anywhere.
I uninstalled it, rebooted, installed it again and still get the same problem.
Is there something that needs to be cleaned up that will fix this?
Are you actually referring to Visual Studio rather than the compiler?
nvaneck
Yes, I belatedly realized that. I'm trying a restore from a previous day; maybe that will correct it.
You could also try an uninstall of Fortran, repair Visual Studio. Make sure it loads. Then reinstall Fortran.
nvaneck
Thsnk, Steve,
I tried that (several times in different ways), tried restoring to previous points, etc. Then tried to install on another machine to make sure my copy of VS still worked--it did.
Ultimately I had to reinstall Windows to get it to work--a 24-hr process to rebuild my develop machine, but it all works fine now. No idea why it ever happened.
