Hi Everyone,
I am trying to learn to how to compile 64-bit libraries with IVF. My questions are
1. How to tell the compiler to compile a 64-bit library. Any switch/option to select?
2. Can I work from my workstation (32-bit Window) and log onto a 64-bit server (64-bit Window)? Or I will need to work from a 64-bit workstation.
3. In compiling a 32-bit library, I need to have ODBC32.lib (come with Microsoft Visual Studio). What is the equivalent one for 64-bit Window system? ODBC64.lib or ODBC64.dll?
Thanks in advance. Good Day.
Tom Lin
Are you using VS2005? That's required if you want to build 64-bit applications in VS.
If so, look at the Intel Fortran on-disk documentation under Building Applications > Building Applications from Microsoft Visual Studio > Specifying a Target Platform for Solutions and Projects. You use a different compiler for the x64 platform, and this is how you select it.
Note that if you have the Professional Edition or higher of Visual Studio, you have to choose a Custom Install and add in the x64 target application option.
You can build 64-bit apps from a 32-bit system, as long as you have the proper support in VS.
It seems to be odbc32.lib on x64 as well. It is provided by VS2005.
Thanks for the prompt reply Steve. Have a great day.
Tom Lin
