29576 Discussions
Compiling Under Visual Studio 2008 Environment
rappal
I am using the Intel Compiler under the IDE of Visual Studio 2008. I had a three line program test.f for which I tried to create an executable. I was able to create an executable when I create a new Configuration Solution as shown below for rkr8. Then it creates an executable rkr.exe in directory rkr8.
1>------ Build started: Project: rkr, Configuration: rkr8 Win32 ------
1>Compiling with Intel Fortran Compiler 10.1.024 [IA-32]...
1>test.f
1>Compiling manifest to resources...
1>Microsoft Windows Resource Compiler Version 6.0.5724.0
1>Copyright (C) Microsoft Corporation. All rights reserved.
1>Linking...
1>Embedding manifest...
1>
1>Build log written to "file://C:Documents and SettingsMy DocumentsVisual Studio 2008Projectssample kr kr8BuildLog.htm"
1>rkr - 0 error(s), 0 warning(s)
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
However if I want to create a debug Configuration solution then I get the following link error and it does not create a debug executable in the debug version.
1>------ Build started: Project: rkr, Configuration: Debug Win32 ------
1>Linking...
1>LIBCMTD.lib(wincrt0.obj) : error LNK2019: unresolved external symbol _WinMain@16 referenced in function ___tmainCRTStartup
1>Debug kr.exe : fatal error LNK1120: 1 unresolved externals
1>
1>Build log written to "file://C:Documents and SettingsMy DocumentsVisual Studio 2008Projectssample krDebugBuildLog.htm"
1>rkr - 2 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
This happens with the release solution also. I do not know why I am not able to create a debug or release version except if the configuration is a new solution.
Rappal
It's not clear from what you have said here, but the error message is a symptom of choosing the wrong project type - Windows Application rather than Console Application. Try creating a new project with type Fortran Console Application and see if that works better for you.
ohadg
Hi Steve,
I have similar problem. I made a mixed C++ Fortran using Intel's VF10.1 and Microsoft VS2008.
The fortran project is a static library project and the C++ is console. I put the F77SUB.lib as additional dependency in my linker->input with the appropriate path.
Iappriciate your help.
Ohad
This is the c++ file:
// F77CPP.cpp : Defines the entry point for the console application.
#include
"stdafx.h"
#include
"fortran.h"
SUBROUTINE F77SUB(REAL* IN,REAL* OUT);
int
_tmain(int argc, _TCHAR* argv[])
REAL IN;
REAL OUT;
IN=1.0;
OUT=1.0;
F77SUB(&IN,&OUT);
return 0;
and this is the Fortran File:
SUBROUTINE F77SUB(IN,OUT)
IMPLICIT NONE
REAL IN
REAL OUT
OUT=5.0*IN
RETURN
END
These arethe compilation errors:
1>------ Rebuild All started: Project: F77SUB, Configuration: Debug Win32 ------
1>Deleting intermediate files and output files for project 'F77SUB', configuration 'Debug|Win32'.
1>Compiling with Intel F ortran Compiler 10.1.021 [IA-32]...
1>F77CPP.FOR
1>Creating library...
1>
1>Build log written to "file://C:F77CPPF77SUBDebugBuildLog.htm"
1>F77SUB - 0 error(s), 0 warning(s)
2>------ Rebuild All started: Project: F77CPP, Configuration: Debug Win32 ------
2>Deleting intermediate and output files for project 'F77CPP', configuration 'Debug|Win32'
2>Compiling...
2>stdafx.cpp
2>Compiling...
2>F77CPP.cpp
2>c:f77cppf77char.h(97) : warning C4996: 'strncpy': This function or variable may be unsafe. Consider using strncpy_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
2> c:program filesmicrosoft visual studio 9.0vcincludestring.h(157) : see declaration of 'strncpy'
2>Compiling manifest to resources...
2>Microsoft Windows Resource Compiler Version 6.0.5724.0
2>Copyright (C) Microsoft Corporation. All rights reserved.
2>Linking...
2>F77CPP.obj : error LNK2019: unresolved external symbol _F77SUB@8 referenced in function _wmain
2>C:F77CPPDebugF77CPP.exe : fatal error LNK1120: 1 unresolved externals
2>Build log was saved at "file://c:F77CPPF77CPPDebugBuildLog.htm"
2>F77CPP - 2 error(s), 1 warning(s)
========== Rebuild All: 1 succeeded, 1 failed, 0 skipped ==========
and this is my linking command line:
/OUT:"C:F77CPPDebugF77CPP.exe" /INCREMENTAL /NOLOGO /LIBPATH:"C:F77CPPF77SUBDebug" /MANIFEST /MANIFESTFILE:"DebugF77CPP.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"C:F77CPPDebugF77CPP.pdb" /SUBSYSTEM:CONSOLE /DYNAMICBASE /NXCOMPAT /MACHINE:X86 /ERRORREPORT:PROMPT F77SUB.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib
What is the contents of fortran.h? It is evidently defining a macro SUBROUTINE that is incorrect for use with Intel Fortran. My guess is that it includes __stdcall - if so, remove it.
ohadg
Hi Steve,
Thanks for the quick response!
I took fortran.hfrom:
http://arnholm.org/software/cppf77/cppf77.htm
and it contains the following lines:
#ifndef
FORTRAN_FROM_CPLUSPLUS
#define
Definitions for calling FORTRAN 77 from C++
Author: Carsten Arnholm, 25-AUG-1995 (first Windows NT impl.)
Rev1 : Carsten Arnholm, 21-DEC-1995 (Unix updates)
Rev2 : Carsten Arnholm, 03-MAR-1996 (f77cmplx.h, f77matrx.h)
manual is available in: http://arnholm.org/software/cppf77/cppf77.htm
typedef
int INTEGER; // INTEGER 4 bytes
typedef
float REAL; // REAL 4 bytes
typedef
double DOUBLE_PRECISION; // DOUBLE PRECISION 8 bytes
typedef
int LOGICAL; // LOGICAL 4 bytes
#include
"f77char.h" // character n bytes
#include
"f77cmplx.h" // complex
#include
"f77matrx.h" // fmatrix class
// values for LOGICAL
#define
FALSE 0
#define
TRUE 1
// Macros for portable handling of linkage & calling conventions
#ifdef
F77_STUB_REQUIRED
// Typically, this branch is for Unix computers
// C++ stub functions:
#define SUBROUTINE inline void
#define INTEGER_FUNCTION inline INTEGER
#define REAL_FUNCTION inline REAL
#define LOGICAL_FUNCTION inline LOGICAL
#define DOUBLE_PRECISION_FUNCTION inline DOUBLE_PRECISION
// FORTRAN functions
#define SUBROUTINE_F77 extern "C" void
#define INTEGER_FUNCTION_F77 extern "C" int
#define REAL_FUNCTION_F77 extern "C" float
#define LOGICAL_FUNCTION_F77 extern "C" int
#define DOUBLE_PRECISION_FUNCTION_F77 extern "C" double
#else
// MS Windows using Microsoft compilers
#define SUBROUTINE extern "C" void __stdcall
#define INTEGER_FUNCTION extern "C" INTEGER __stdcall
#define REAL_FUNCTION extern "C" REAL __stdcall
#define LOGICAL_FUNCTION extern "C" LOGICAL __stdcall
#define DOUBLE_PRECISION_FUNCTION extern "C" DOUBLE_PRECISION
__stdcall
#endif
#endif
f77char.h f77cmplx.h, and f77matrx.h are described in the above link.
Thanks!
Ohad
ohadg
I deleted the line "__stdcall" and now I get the following massages:
1>Compiling with Intel Fortran Compiler 10.1.021 [IA-32]...
1>F77CPP.FOR
2>Compiling...
2>stdafx.cpp
1>
1>Build log written to "file://c:F77CPPF77SUBDebugBuildLog.htm"
2>Compiling...
2>F77CPP.cpp
2>Linking...
2>LINK : fatal error LNK1104: cannot open file 'ifconsol.lib'
2>F77CPP - 1 error(s), 1 warning(s)
ohadg
I got It - I just added the :
C:Program FilesIntelCompilerFortran10.1.021IA32Lib
into the addtional library path in the linker.
It works great!
No I'll try more complicated code which worked already under VC++6 and VF6.
Thanks !
Ohad
