29386 Discussions
Compiling programs to be used on 32b machines
desouzasantos
I acquired a PC working on 64b. However, I need to compile programs that can be used on 32b machines. They should also use IMSL libraries. Which compilers should I use? Thank you.
You would use the compiler for "IA-32 Applications" - it runs on 64-bit systems. The current compiler is not yet available with IMSL - we are working on completing the qualification process.
