29657 Discussions
Compiling source code with modules under VS 2008 IDE
jyeoman
Can source code that contains modules be compiled within the VS 2008 IDE to produce .mod files? If so, how is it done? If not, how are .mod files compiled from the source code?
Andrew_Smith
Valued Contributor I
Yes. Compile the source code.
Paul_Curtis
I think what the OP has missed is that .f90 source files must first be associated with a project before they can be compiled. The steps are to create a project, and then add the (existing) source files to the project.
Wendy_Doerner__Intel
Wendy
Attaching or including files in a post
If the problem is how to create and add files to a project, this tutorial might be of help.
