Compiling with ifort
angiekia
We have the new Intel compiler (11.0) installed at our Linux machines at University. The previous version we were using was 9.1.043. In order to compile something i was running the following commands (using libraries as well)
ifort -c *.f
ifort **.o **.o -L. -l** -o **
With the new one, when i run the first command, I get
**.f(103): (col. 7) remark: BLOCK WAS VECTORIZED.
**.f(147): (col. 7) remark: LOOP WAS VECTORIZED, and another 100 of these.
Then i move one to the second line and i get this
ld: skipping incompatible ./lib**.a when searching for -l**
ld: cannot find -l**
However lib**.a exists in the folder and everything was working before.
What do I have to with the new compiler to make it to work again?
Any help would be appreciated.
TimP
Quoting - angiekia
This generally indicates you attempted a mixture of 32- and 64-bit objects. While the x86_64 linux has support for both 32- and 64-bit execution, it doesn't support linking them together.
Supposing that 'file *.a' indicates these are 64-bit objects, you must use the 64-bit compiler, such as you would get on PATH by
'source /opt/intel/Compiler/11.0/081/ifortvars.sh intel64'
You could check which compiler you have active by 'ifort -V'
angiekia
Quoting - tim18
I was using the intel 64 and changing to 32 bit solved the problem. Thanks!
As to the * (col. 13) remark: LOOP WAS VECTORIZED. can i somehow turn this off- so as not to see them on the screen? I have a lot of fortran codes that are compiled every time - and it justs clutters my screen.
Thanks again!!
TimP
Quoting - angiekia
-vec-report0 turns off vectorization messages. Apparently, it's the default for the next release.
angiekia
Quoting - tim18
Thanks so much for your help! Everything is running smoothly now...
