Compiling with mpif90
Greg_R_
Let me start off by says I am not a programmer. I am an SA who installed the Intel suite of compiler. I have a little HelloWorld program that I installed. Do the Intel compilers still use the gfortran that is on the system?
mpif90 -o intel-f90 intel-impi-hello.f90
[ramos@sandy ~]$ ldd intel-f90
        linux-vdso.so.1 =>  (0x00007ffe43da5000)
        libmpifort.so.12 => /software/depot/xe_2017-update-1/compilers_and_libraries_2017.1.132/linux/mpi/intel64/lib/libmpifort.so.12 (0x00002b6c78821000)
        libmpi.so.12 => /software/depot/xe_2017-update-1/compilers_and_libraries_2017.1.132/linux/mpi/intel64/lib/libmpi.so.12 (0x00002b6c78bca000)
        libdl.so.2 => /lib64/libdl.so.2 (0x000000353ee00000)
        librt.so.1 => /lib64/librt.so.1 (0x000000353fa00000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x000000353f200000)
        libgfortran.so.3 => /usr/lib64/libgfortran.so.3 (0x00002b6c798f6000)
        libm.so.6 => /lib64/libm.so.6 (0x000000353f600000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003541200000)
        libc.so.6 => /lib64/libc.so.6 (0x000000353ea00000)
        /lib64/ld-linux-x86-64.so.2 (0x000000353e600000)
[ramos@sandy ~]$
jimdempseyatthecove
No.
Make sure you source the appropriate ...sh files, then use mpiifort (mpi ifort as one word).
Jim Dempsey
Greg_R_
source /software/depot/xe_2017-update-1/compilers_and_libraries_2017.1.132/linux/mpi/intel64/bin/mpivars.sh
[ramos@sandy ~]$ which mpiifort
/software/depot/xe_2017-update-1/compilers_and_libraries_2017.1.132/linux/mpi/intel64/bin/mpiifort
[ramos@sandy ~]$ mpiifort -o intel-impi-helloworld intel-impi-hello.f90
[ramos@sandy ~]$ ldd intel-impi-helloworld
        linux-vdso.so.1 =>  (0x00007fffbbfa1000)
        libmpifort.so.12 => /software/depot/xe_2017-update-1/compilers_and_libraries_2017.1.132/linux/mpi/intel64/lib/libmpifort.so.12 (0x00002ae492c07000)
        libmpi.so.12 => /software/depot/xe_2017-update-1/compilers_and_libraries_2017.1.132/linux/mpi/intel64/lib/libmpi.so.12 (0x00002ae492fb0000)
[ramos@sandy ~]$
jimdempseyatthecove
In both cases it appears that at least the Intel libraries are used. As for the compiler, you have yet to show the compiler banner as the result of mpiifort-o intel-f90 intel-impi-hello.f90
and
The source statement you showed is sourcing the MPI system, but not necessarily the compiler selection. This would be done via:
source /software/depot/xe_2017-update-1/compilers_and_libraries_2017.1.132/Linux/bin/compilervars.sh intel64
Due to the fact that "which" located mpiifort it seems to imply that at some point the compilervars was sourced.
Jim Dempsey
Greg_R_
Thank you for the information. I guess I don't understand the comment regarding the Intel banner. When I use either mpif90 or mpiifort, the program just compiles and returns to the command line, I don't see and banner.
Greg
Greg_R_
I added the 'V' switch:
mpiifort -V  -o intel-impi-helloworld intel-impi-hello.f90
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
 Intel(R) Fortran 17.0-1632
GNU ld version 2.20.51.0.2-5.47.el6_9.1 20100205
Greg
Lorri_M_Intel
So, is everything OK, once the startup script was sourced, or is there still a problem?
#3 looked OK to me; just want to make sure I didn't miss something
           thanks -
                   --Lorri
Greg_R_
Hi Lori. I have always been able to compile, my question is in regards to the gfortran library showing up, is that normal?
Greg
TimP
In the original post you were compiling with gfortran so the corresponding library was linked.
Greg_R_
No, I was NEVER compiling with gfortran, that is the point of my post. I was using mpiifort and mpif90 to compile. My question was how come the executable shows up with links to gfortran and if that is normal?
Greg
Steve_Lionel
mpif90 tends to invoke gfortran. The mpixxx commands are just scripts that invoke a particular compiler along with appropriate options for MPI use.
Greg_R_
OK, thank you. The last examples have used mpiifort and I still see a link to a gcc library.. Is that is what to be expected:
        linux-vdso.so.1 =>  (0x00007ffd5fdde000)
        libmpifort.so.12 => /software/depot/xe_2017-update-1/compilers_and_libraries_2017.1.132/linux/mpi/intel64/lib/libmpifort.so.12 (0x00002b49eb5f3000)
        libmpi.so.12 => /software/depot/xe_2017-update-1/compilers_and_libraries_2017.1.132/linux/mpi/intel64/lib/libmpi.so.12 (0x00002b49eb99c000)
Greg
Steve_Lionel
Yes, Intel Fortran uses libgcc.
Greg_R_
Thank you. All of my questions have been answered.
Greg
