29559 Discussions
Complex Matrix Assign Crashes in IFORT 16.0.3
John_Y_
Attached is a simple test case that crashes on a complex matrix assign in ifort 16.0.3.  It works with all previous ifort versions I have used.  The crash occurs when using the cmplx intrinsic and does not occur when not using the intrinsic.  For example,
          zz = cmplx(0._db,0._db,db) ! db defined in test file
crashes but
         zz = 0._db ! db defined in test file
does not.  My compile line is
       ifort -traceback testZ8.F90
John
Kevin_D_Intel
Thank you for the report and reproducer John. We'll look into this.
Kevin_D_Intel
This appears related to the creation of array stack temporaries. The program runs with pre-16.0 compilers without any aid and runs with 16.0 compilers with the aid of either -heap-arrays or elevating the shell stack limit (i.e. ulimit –s unlimited).
I need to consult others whether the changed behavior was anticipated with 16.0. I'll update after learning more.
For convenience I included your test case below.
program test
  implicit none
  integer, parameter :: db = kind(1.0d0)
  integer, parameter :: sg = kind(1.0)
  integer, parameter :: stdout = 6
  ! local variables
  integer :: itmp, i, ierr, m
  complex(db), allocatable :: zz(:,:)
  complex(sg), allocatable :: cc(:,:)
  m = 5868
  allocate(zz(m,m),stat=ierr)
  write(stdout,*) 'IERR: ', ierr
  allocate(cc(m,m),stat=ierr)
  zz = 0._db ! This line ok
  zz = cmplx(0._db,0._db,db) ! This line crashes
  cc = 0._sg ! This line ok
  cc = cmplx(0._sg,0._sg,sg) ! This line crashes
  deallocate(zz,cc)
end program test
John_Y_
Kevin,
Using "-heap-arrays" is a simple enough workaround.  It's interesting the behavior changed though.
John
In version 15, the compiler did a simple element-by-element initialization in a loop. In version 16 it created an array temp for the whole initialized array and copied it - this triggered the stack overflow. In the upcoming version 17, it generates a vectorized loop to more efficiently set the values and doesn't use a temp.
