Computation time
ekeom
Dear All,
I wrote two "identical" fortran routines : test_1 and test_2. Only line 29 is diffrent
test_1 line 29 is : a(i1) = sum(v(1:n)*b((j-1)*n +1:j*n))
test_2 line 29 is : c = sum(v(1:n)*b((j-1)*n +1:j*n))
But computation time is very different. Here are CPU time in secondes for different values of n.
test_1 time test_2 time
n = 500 0.905 0.016
n = 1000 7.207 0.016
n = 1500 24.523 0.047
n = 2000 58.641 0.109
I need to keep the array a. How can I change test_1 to make it as faster as test_2?
Didace
Ps : see source code bellow
subroutine test_1 (a,b,n)
use const_m
implicit none
integer, intent(in) :: n
integer :: i, j, p
complex*16 :: c
complex*16, dimension(n), intent(inout) :: a
complex*16, dimension(n), intent(in ) :: b
complex*16, dimension(:), allocatable :: v
allocate(v(n))
do i=1,n
v(:) = a(i:(n-i1)*n +i:n)
p = i -n
do j=1,n
p = p +n
enddo
enddo
deallocate(v)
end subroutine test_1
subroutine test_2 (a,b,n)
use const_m
implicit none
integer :: i, j, p
complex*16 :: c
allocate(v(n))
do i=1,n
p = i -n
do j=1,n
p = p +n
enddo
enddo
deallocate(v)
end subroutine test_2
jimdempseyatthecove
The "problem" you are seeing might not be a problem at all.
When you perform the "c = sum..." in the loop the optimization code of the compiler will note that c is not referenced in the loop, therefore all iterations of the loop excepting the last iteration may be eliminated.
Try inserting following "c = sum..."
if(c .eq. b) write(*,*) 'eq' ! use for timing test only
Where you expect c to never equal b
i.e. you want to insert an if statement using c that will never succeed. This will force the optimization code to not eliminate iterations of your loop.
Then run the timing test and compare the results.
Jim Dempsey
ekeom
Thank Jim Dempsey,
I have run the test. I got the results then previously.
Didace
jimdempseyatthecove
Then try using the temp
[cpp]c = sum(v(1:n)*b((j-1)*n +1:j*n))
a(i1) = c
[/cpp]
Jim Dempsey
ekeom
Sorry, It me again. I try a new test, you are right test_2 timing is equivalent to test_1 with if(c.eq.b)...
Best regrads,
Didace
jimdempseyatthecove
So then the "problem" was optimization did not provide comparable example.
For speed-up try replacing the = sum(... with an equivilentloop
The purpose being to see if the compiler generates better vectorization of code.
Then next improvement (when n is large) would be to use OpenMP on the loop.
That is
assure vectorization is use when possible
then use parallization when appropriate
Jim Dempsey
