Conditional compilation
w_a_kramer
Why doesn't the following code function?
  !DEC$ IF DEFINED ($DLL)
    USE DllGlobals
  !DEC$ ENDIF
whereas
  !DEC$ IF DEFINED($DLL)
    iGuarantee=0
  !DEC$ ENDIF
functions OK.
The conditional compilation seems to be completely ignored for use statements.
Even if $DLL is not defined the compiler starts complaining about not finding the DllGlobal.mod file.
Walter Kramer
Jugoslav_Dujic
Valued Contributor II
No, it works in both cases. You're probably confused by the complaints about "Cannot find DllGlobals.mod" -- these come from dependency analyser, which scans source files to build dependency tree before any actual compiling. These messages are benign -- compiler will not actually USE the module.
Let me warn you, however, that the !DEC$ IF style of conditional compilation operates on a per-statement mode, not per-line as you might think. You can't use !DEC$ IF to conditionally add to or subtract from part of a statement.
Steve
