Configuring for Use IMSL from Microsoft Visual Studio
Zenghu_C_
I just purchased and installed Intel Fortran compiler 2016 and the latest IMSL.  Why don't I see Intel Parallel Studio XE in Tools>Options?
Steven_L_Intel1
In Tools > Options it's now "Intel Compilers and Tools". I see that I need to update the article (https://software.intel.com/en-us/articles/installing-and-using-the-imsl-libraries/)
Zenghu_C_
Thank you for the help. I can use IMSL now with no issues.
I need your help to use MKL. I added " C:\program files....\mkl\lib\interl64"  to Project\properties\Linker\General\Additional Library Directories.  However, when I built a project using a old code for Fortran 10, a link error #11018 shows up. What else should I do to use MKL?
Steven_L_Intel1
Did you really put in "interl64"? That should be "intel64". But easier is simply to set the "Use Intel Math Kernel Library" option under Fortran > Libraries to Parallel. However, the path to the MKL libraries is generally set by default.
I don't think there is a linker error 11018. What is the exact message you get?
