Thanks to Jugoslav, I can now update output to a dialog box without having it disappear or require user interaction. However, when putting my code into the computational area of Jugoslav's example and putting in the appropriate USE statements, I now have a conflict with a variable called DLT. This variable contains the current timestep as I integrate hydrodynamic equations over time.
Needless to say, this variable occurs all over the place in the code. Rather than renaming hundreds of instances of DLT in my code, I was hoping to rename DLT in the appropriate DFxxxxx module, but DLT is nowhere to be found in the CVF modules. Any suggestions as to where else this conflict may be arising?
I'm not aware of a DLT symbol in the CVF-supplied modules. Search the other modules you use. Or better, use ONLY clauses on all the modules to bring in just the symbols you want.
Steve
Steve
D'oh, DLT is a stupid PARAMETER defined in DFWINTY.f90, related with DeviceIOCtl API.
Either:
1) USE DFWIN, ONLY:
Either:
1) USE DFWIN, ONLY:
or
2) USE DFWIN, Fred=>DLT
(to rename the offending symbol into "Fred")
Jugoslav
