29331 Discussions
Confused about /Og switch in Visual Studio 2008
Henrik_S_
According to the documentations the default is "Global Optimizations" /Og to be enabled unless /Od is specified. In VS under Properties > Configuration Properties -> Fortran -> Optimization the default setting for Global Optimization is "No" with the option of turning it on "Yes /Og". So what does this setting do since (if the docs are correct), /Og is turned on by default? Furthermore the default "No" in Global Optimization is incorrect or at least misleading since Global Optimizations are turned on by default.
Finally, what does the "/Og" flag do? The Documentation on "/Og" say nothing of interest.
- Henrik
/Og is intended to be equivalent to Microsoft's /Og. It is an old switch and basically controls general optimizations that the compiler would do normally. It is on by default unless optimizations are disabled (/Od).
My advice is to ignore this. Microsoft says it is "deprecated". I am going to recommend that it be removed from the property pages,
This property was removed for 11.1
