Confused by this Intel Compiler
Wen_C_
Hi, I recently bought Intel Fortran Compiler and I followed the tutorial to run a simple Fortran code which ran well on MS Fortran Power Station and Digital Fortran, here is what I did:
Visual Studio 2013 - File - New Project - Intel Visual Fortran - Console Application - Empty Project - then Project - Add Existing Item (add my simple Fortran code) - Build - Build Solution - Then DEBUG - Start with Debugging (the program would not run), but If I used Start Debugging, below are the error messages I received.  Please help.
'Test3.exe' (Win32): Loaded 'C:\0_Fortran\Test3\Test3\Debug\Test3.exe'. Symbols loaded.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\ntdll.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\kernel32.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\KernelBase.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Program Files (x86)\Intel\Composer XE 2015\redist\ia32\compiler\libifcoremdd.dll'. Module was built without symbols.
'Test3.exe' (Win32): Loaded 'C:\Program Files (x86)\Intel\Composer XE 2015\redist\ia32\compiler\libmmd.dll'. Symbols loaded.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\imagehlp.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msvcrt.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\advapi32.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\sechost.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\rpcrt4.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\sspicli.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\cryptbase.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Program Files (x86)\Intel\Composer XE 2015\redist\ia32\compiler\libifportmd.dll'. Module was built without symbols.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\user32.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\gdi32.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\lpk.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\usp10.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msvcr120d.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\imm32.dll'. Cannot find or open the PDB file.
'Test3.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msctf.dll'. Cannot find or open the PDB file.
Run-Time Check Failure #2 - Stack around the variable '_RUNTIME$IHOUR' was corrupted.
Only the last message is interesting, the others can be ignored. Continued in your other thread.
