Congratulations
JohnNichols
Honored Contributor I
Steve:
You should give a big pat on the back to the group that put the help files into HELP VIEWER 1.1. This is a huge improvement, as good now as the Powerstation manuals which I keep at my bedside. My only comment is that difficulty in getting the code out, one now gets a lot of HTML.
Interesting HELP VIEWER 1.1 works on my desktop but not my dell precision, both running WIN7 64 bit.
Any ideas?
PS: Happy Christmas, I forgot weeks ago.
PS1: I had some old Fortran code that was written from an older BASIC code, Bill Gates BasicA not modern basic. I could get GWbasic running on a WIN7 64 bit machine, but it was as freaking slow as the old days.
Life is short play hard.
JMN
Wendy_Doerner__Intel
Valued Contributor I
Maybe one system has been upgraded to SP 1 and the other not?
JohnNichols
Interesting, it just starting doing it from the desktop as well.
Stock standard WIN7 installation with VS 2010 and Intel Fortran.
i do have VS 11 installed as well.
JMN
How is it not working? You should be able to select the following:
Help => Intel Visual Fortran Composer XE 2011
and see something like this page:
http://127.0.0.1:47873/help/2-7444/ms.help?product=VS&productVersion=100&method=f1&query=intel.for.main_cover_xe12&locale=en-US&DevLang=intelfor&category=DevLang%3aIntelFortran
What do you see when you follow those steps? Note to get the this help you need to configure instalation for local help as noted in this article.
Also did you intialize the "Local Store"? See the information on how to do this from the release notes.
2.2.5 Additional Steps to Install Documentation for Microsoft Visual Studio 2010
When installing Intel Visual Fortran Composer XE 2011 on a system with Microsoft Visual
Studio 2010 for the first time, you will be asked to initialize the Local Store for documentation
for Visual Studio 2010 if it was not done before. The "Help Library Manager" will register the
Intel Visual Fortran Composer XE 2011 help documentation within Visual Studio 2010. Please
follow the instructions of the "Help Library Manager" installation wizard to install the Intel Visual
Fortran Composer XE 2011 help documentation for Visual Studio 2010.
This step is only needed once. When you install Intel Visual Fortran Composer XE 2011
updates in the future, you will not be required to re-register the documentation through the Help
Library Manager.
For the more information, see http://msdn.microsoft.com/en-us/library/dd264831.aspx or search
on microsoft.com for Help Library Manager.
Wendy
Attaching or including files in a post
