29568 Discussions
Console app in debug : module built without symbols
alexandre_c_1
I am trying to built a console app in debug config. The exe is triggering a breakpoint and I get the message saying that the module libifcoremdd.dll was built without symbols
'ifort.exe' (Win32): Loaded '\\hqfs2\pengen\2013\UVS\Version\V1\ifort\Debug\ifort.exe'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\ntdll.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\kernel32.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\KernelBase.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\sysfer.dll'. Cannot find or open the PDB file.
'ifort.exe' (Win32): Loaded 'C:\Program Files (x86)\Intel\Composer XE 2015\redist\ia32\compiler\libifcoremdd.dll'. Module was built without symbols.
'ifort.exe' (Win32): Loaded 'C:\Program Files (x86)\Intel\Composer XE 2015\redist\ia32\compiler\libmmd.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\imagehlp.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msvcrt.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\advapi32.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\sechost.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\rpcrt4.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\sspicli.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\cryptbase.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Program Files (x86)\Intel\Composer XE 2015\redist\ia32\compiler\libifportmd.dll'. Module was built without symbols.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\user32.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\gdi32.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\lpk.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\usp10.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msvcr110d.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\imm32.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\msctf.dll'. Symbols loaded.
'ifort.exe' (Win32): Loaded 'C:\Windows\SysWOW64\dbghelp.dll'. Symbols loaded.
I am stuck there. Note: When I build in release configuration I do not get the message.
Is there any symbol file for libifcoremdd ?
How can I go pass that ?
Thank you
mecej4
You can ignore the warning about the runtime DLL not containing symbols, except when you want to debug the runtime itself. Warnings of this type are normal. You get the warning only when you use a debug configuration and one of the libraries linked does not contain debug information.
You don't say how you are "stuck", but I think I know what you refer to - Visual Studio doesn't let you do anything unless you can provide a path to the Run-Time Library DLL symbols, and we don't provide them. This is new behavior for VS and it's under investigation. As a workaround,  change the Libraries > Use Run-Time Libraries setting to "Multithreaded" instead of "Multithread DLL". It's curious that it doesn't affect all programs.
alexandre_c_1
It seems like the change of "Run-Time Libraries setting to "Multithreaded" instead of "Multithread DLL" have worked as a workaround the symbol problem for the libifcoremdd.dll' and the libifportmd.dll. Thank you steve.
