Constant File Parsing
Jacob_Williams
New Contributor III
Visual Studio seems to have started going crazy parsing my source files.  Everytime I press any key, I see the message at the bottom of the dialog that says "Parse file <filename>".  The constant delay from doing this is an big annoyance.  How do I turn this off?  In Options -> Fortran -> Advanced, I have everything set to False, except for "Disable Database", which I set to True.  It doesn't seem to help.  I'm using VS 2010, with the 2015 version of the compiler (initial release).
You need to restart VS to have those options take effect. I have previously reported this issue to the developers. Normally this reparsing isn't a problem, but it is for some configurations.
Jacob_Williams
New Contributor III
Hmmm, I still see the parse message (after every return, or if I stop typing for 1 sec).  But, I don't see the same delay.  So maybe it's not really parsing the file now?
