Conversion Problems
kyudos
I've just converted a VS6 MFC/CVF application to VS2010 with IVF Composer XE 2011.
I've checked my integreation and set my library directories.
Hoever, the converted Fortran projects do not appear to be configured to compile correctly (no Custom Build info).
Did I do something wrong or does something need to be done manually?
Yes - converting a CVF project is a two-step process. Unfortunately, there's no way we can prompt you to take the second step - you have to have read about it in the documentation or in this article on Migrating from CVF. We are looking at ways to introduce the product better on installation.
kyudos
Thanks Steve - figured I was missing something!
