29640 Discussions
Convert array of objects into array of properties
S__MPay
Say I have an array of class People called Employees,
ArrayOfEmployedAtAge  = Employees(:)%BirthDate - ArrayOfEmployedDate
The result is
error #6159: A component cannot be an array if the encompassing structure is an array.
IanH
Is the BirthDate component a non-allocatable, non-pointer, integer scalar?  If so... Employees%BirthDate will be an integer array (the (:) bit is frippery in this context).  If not... it will be something else, possibly an error.
As per #2... please show the declarations.
Arjen_Markus
You are not clear about:
  • The question you want an answer to (I guess it is: how to solve the compile error, but then we need information on what you actually want to do)
  • The declaration of the various variables. I guess from the error message that BirthDate, the one component in this statement, is not a scalar, but given the missing declarations, it is no more than a guess
Please provide the missing information, so we can help.
S__MPay
I want to make a integer array from the birth date of employees. But Employees is an array of objects and the birth date is only a property.
Question: Is there a syntax error in this line?
Will Employees(:)%BirthDate return an integer array of BirthDates?
If not what is the right way of doing that (without making a loop)?
IanH
