Converting a character variable to a real variable
Carlos_S_
Please,
Someone could explain me how to convert a character variable get from an edit box to a real variable, using just a command? I am developing a Win32 program.
Thank you in advance.
Carlos Santos
Arjen_Markus
I do not know how you get the character string from an edit box, but you can convert the character string to a real value by using an internal read:
character(len=20) :: string
real :: value
read( string, * )  value
(You will probably want to add some error handling code here)
Carlos_S_
Dear arjenmarkus,
This kind of procedure doesn´t work in Win32 programs. I tried it but it didn´t work.
Thank you for your suggestion.
Carlos Santos.
mecej4
You did not say what you tried, so there is not much to say about it. However, you seem to be unaware of a rather important principle. Fortran neither knows nor cares about an "edit box", just as it does not know about "black holes". A string is a string, whether it is engraved on a tombstone or is input through an edit box. A READ statement such as the one that Arjen Showed will work as long as the contents of string are suitable for being read as a real value. Whether the program is a Win32 program, a VMS program or one that controls a diesel engine is completely immaterial.
How you place the text that a user typed into an edit box into a string variable is specific to the OS and the API that you use. That, however, is not a Fortran question per se.
andrew_4619
How is the edit box created?
rase
Paul Burkardt has assembled a huge library of Fortran subroutines (http://people.sc.fsu.edu/~jburkardt/f_src/chrpak/chrpak.html) for converting characters and character strings to all kinds of variables and vice versa. Have a look at the descriptions and the sources. Internal read of a character string is widely used, also in Paul's routines, but he added a few error checks to analyse weird strings.
andrew_4619
assuming your dialog edit box was made with the windows api and not quickwin:
use IFWIN, only: dword, SetDlgItemText, GetDlgItemText, handle
integer(handle)  :: hDlg
integer          :: ID_of_editbox_control
integer(DWORD)   :: ret
character(80)    :: gout, gin
! to set
gout='my text'//achar(0) ! null terminated string
ret = SetDlgItemText (hDlg, ID_of_editbox_control, gout ) !dialog handle and control ID
!to get text
ret = GetDlgItemText(hDlg, ID_of_editbox_control, gin,len(gin))
jimdempseyatthecove
Adding to app4619's are the comments made earlier:
The data obtained in gin is the text of what was in the edit box. In the #7 example, this edit box is assumed to not have more than 80 characters of data. The data you type into the edit box must be convertible per-Fortran data representation:
Valid: 123456.78
Not valid: $123,456.78
Jim Dempsey
