29329 Discussions
Correct Intel option(s) to detect out-of-bounds
Matt_Thompson
All,
A colleague of mine whipped up this code:
program omg
  implicit none
  integer, dimension(:), allocatable :: arr
  allocate(arr(2:1))   ! some allocations are designed to give a size of zero
  write(6,*) size(arr) ! and this is what happens
  arr(1) = 2           ! but why doesn't the ifort bounds checker detect this as out-of-bounds?
  write(6,*) arr(0)    ! or even this?
  print*, lbound(arr), ubound(arr)
end program omg
and when we run with NAG Fortran, we get an error:
@$ nagfor -C=all test.F90
NAG Fortran Compiler Release 7.2(Shin-Urayasu) Build 7201
[NAG Fortran Compiler normal termination]
mathomp4@gs6101-bucy ~/F90Files/OutOfBounds
@$ ./a.out
 0
Runtime Error: test.F90, line 7: Subscript 1 of ARR (value 1) is out of range (2:1)
Program terminated by fatal error
Aborted (core dumped)
 With GCC 13.2, an error:
@$ gfortran --version
GNU Fortran (GCC) 13.2.0
Copyright (C) 2023 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
@$ gfortran -O0 -g -fcheck=all test.F90
@$ ./a.out
           0
At line 7 of file test.F90
Fortran runtime error: Index '1' of dimension 1 of array 'arr' below lower bound of 2
Error termination. Backtrace:
#0  0x400a31 in omg
	at /home/mathomp4/F90Files/OutOfBounds/test.F90:7
#1  0x400d1e in main
	at /home/mathomp4/F90Files/OutOfBounds/test.F90:11
However, we can't seem to get Intel to trigger on it. Neither ifort:
@$ ifort -diag-disable=10448 -V
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.12.0 Build 20240222_000000
Copyright (C) 1985-2024 Intel Corporation.  All rights reserved.
@$ ifort -check all  -init=snan,arrays -diag-disable=10448 test.F90
@$ ./a.out
           0
    22667968
           1           0
Nor ifx:
@$ ifx -V
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.1.0 Build 20240308
@$ ifx -check all  -init=snan,arrays test.F90
@$ ./a.out
           0
           0
           1           0
seem to. My guess is I'm just not passing in the right option. We usually use `-check all -init=snan,arrays` for most of our debugging runs, but they don't seem to trip this.
