29487 Discussions
Could not create fortran projects within MS 2005 Premier Partner Edition.
danielwood
Installed intel visual fortran 11 with MS 2005 Premier Partner Edition on a Windows XP-64 PC.
The installation was OK. However, after the installtion was finished, there is no fortran project type to choose within MS 2005 Premier Partner Edition. In other words, could not create any fortran projects within MS 2005 Premier Partner Edition.
Any solutions?
Thank you so much.
Try running the program in the attached ZIP. If it displays any errors, please post them in a reply here.
danielwood
Hello Steve:
The problem is solved. Thank you so much for your help.
