29352 Discussions
Could "CreateProcess" call the command of "copy"?
intelhelp2009
I tied to use "CreateProcess" to copy file and theCMDLINE is like:
CMDLINE= 'Copy file1.txt file2.txt'
Hoever it didn't work. Is there a way to copy file by using "CreateProcess"?
Thanks!
You'd be better off using ShellExecute, but there is also a CopyFile routine. See the samples under Miscellaneous\CopyFolder. CreateProcess probably could be used, but it's more complicated to set up.
