Crash on return from subroutine
Don_D_
This is a weird problem.  Fortran subroutine A calls B.  B calls C.  C calls a c++ routine that spawns several processes.
Those processes complete, and C terminates them.  C returns to B.  B returns to A.
In debug mode all is well.  The release version crashes when B returns to A.  "Access violation reading location ...".
Any thoughts as to what is going on?  The code is huge, so I can't list it here.  I put a statement that writes to a window when B returns.  It never gets there.
How can I diagnose what is going wrong?  As I said, weird.
ZlamalJakub
New Contributor III
You should study Mixed Language Programming
https://software.intel.com/en-us/fortran-compiler-developer-guide-and-reference-mixed-language-programming
Crash is caused by different conventions of calling routines in Fortran and C.
I have found some samples at
https://software.intel.com/en-us/node/611723
Don_D_
While that is a good suggestion, be aware that my code calls c++ all over the place and has been working just fine for years.  So I think I got the calling conventions under control.
What's different this time is the c++ spawning other processes.  If I disable that step everything works as it should.
So the question is, why would spawing and then killing those processes cause a return from Fortran to Fortran to crash.  There are no calling conventions at play there.
ZlamalJakub
New Contributor III
I have following suggestions then:
1. Program crashes during return from B to A? Or let's say code write(*,*) 'Return' can be executed after C++ call?
   If it crashes during return then problem should be in stack corruption - i.e. wrong calling convention.
   If it crashes after return, some of spawned process probably manipulated some pointer to your fortran data. Is it possible that some process can write out of bounds of your Fortran arrays?
2. Acces violation reading location ... shows some nonzero address?
3. Try to enable spawning another processes step by step and find which causes the error. Then try to comment parts of this code to see which routine causes the problem.
andrew_4619
I agree with Jakub, is clear case of Stack corruption IMO. Mismatched call parameters or calling conventions. Also mismatch intent in args e.g. trying to modify something passed as a constant.
jimdempseyatthecove
Add to Jakub's advice is to spawn the processes as you do now, however, setup these process such that they do not do anything productive. If you are structured to kill these processes as opposed to join with them, then place them in a innocuous spin loop. Leave the original compute code in place such that should this test configuration result in your application not crashing, then you can one-by-one enable each of these processes original code to see where the problem occurs.
This is often an indication that the code my have worked by accident rather than by design. IOW the juxtaposition of code and data were such that errant writes were not exposed by means of crash or abnormal behavior of the application.
Jim Dempsey
