The following code gives "floating divide by zero" with O2:
module MDivZero
implicit none
public
contains
subroutine test(n, arr, arrOut)
integer ::i, n
real(4) :: arr(:), arrOut(:)
arr = 1.0
do i = 20, n,20
arr(i) = 0
enddo
arrOut = 1.0
do i = 1, n
if(arr(i).gt.1) then
arrOut(i) = arrOut(i) / arr(i)! Crashes in production code, but works here!
else
arrOut(i) = 0.0
endif
enddo
arrOut = 88.0
where (arr.gt.1)
arrOut = arrOut / arr ! Crash!
elsewhere
arrOut = 0.0
endwhere
end subroutine test
endmodule MDivZero
program Console1
use MDivZero
implicit none
integer :: n = 1000
real(4), allocatable :: arr(:), arrOut(:)
allocate(arr(n), arrOut(n))
call test(n, arr, arrOut)
end program Console1
This does not happen in debug mode/without optimizations. It also does not happen when the arrays are local to the subroutine instead of being passed in.
In my production code this does not only happen in where...elsewhere but also in ordinary do-loops - this I could not reproduce in this small sample.
Please provide a complete reproducer.
Hi Steve,
the given code is a complete program that crashes, can you specify what´s missing?
thanks!
Sorry, I overlooked the main program.
It does not crash for me. I do note that the way you wrote this, arrOut elements will never get set to anything but zero, since all elements of arr are either zero or 1, so none of the assignments will happen. I modified it to set some elements to 1.5 and got reasonable results.
Your "works for me" has been very helpful! I compared my project settings to the default ones and it turns out this only happens when using /fpe:0 (and optimization /O2). Using that it crashes even when initializing arr = 1.0 and no zeros at all and a condition where no division should be executed:
arr = 1.0
arrOut = 1.0
where (arr.gt.10.0)
elsewhere
arrOut = 0.0
endwhereOnly if you change the operator to anything but '/' it works. Btw. the error does not say "zero division" but "floating invalid".
Interesting. I found that I could reduce n to 40 and still get the error, below that not. What I can determine is that the code has vectorized and a vector divide is being done in the where loop with xmm15 loaded with some NaNs. I haven't investigated further, but there is definitely a bug here. I would not expect vector instructions in the where.
I had a chance to dig in a little more, ignore my previous reply, which I deleted.
Check your options to see if you have /fast or the combination of /Qipo /Qxhost
There seems to be an interplay with these 2. Steve may be right, there may be a vectorizer bug here with the use of IPO and processor targeting. Without either there is not fp error.
I will keep digging deeper to see if there is a bug. Sure is looking like it.
ron
I didn't use either /Qipo or /Qxhost and got the error. All I needed to add to the default /O2 was /fpe0.
you beat me to it - seeing the same here also. I was chasing a red herring. I'll use opt-bisect-limit to find the phase and write it up. Appears to be a regression in the vectorizer.
It appears I did not post the bug ID. It is CMPLRLLVM-63857
We hope to have a fix for the 2025.1 release, it is being worked on this week.
