CreateVFProject
rftap
I try toadapt default.js to set up my own type of IVF project. Can anybody please tell me how to retrieve the properties and methods of the object generated by CreateVFProject.
I would like to automatically set the FPP switch, but I can not find how to do that.
Frank
rftap
I tried to add:
tool.GeneratePreprocessedFile = preprocessOption.preprocessYes
but I get the following error message:
Error in AddConfigsDLL: Object doesn't support this property or method
Frank
Jugoslav_Dujic
Valued Contributor II
I don't see if the documentation of VF compiler and other tools' VS Object model is available, but you should be able to solve the problem by a bit of reverse engineering. The VFtool object properties names and values are visible in the .vfproj source file, so you can deduce it for yourself:
  • save a copy of an original .vfproj file
  • change the appropriate compiler switches in IDE and save the project
  • compare the two .vfproj using a diff tool (e.g. http://winmerge.org/)
Using that method for /fpp switch, I found out that the difference is
 Preprocess="preprocessYes"
thus, the appropriate syntax is probably
 tool.Preprocess = preprocessOption.preprocessYes, or just
 tool.Preprocess = preprocessYes
HTH
Jugoslav
rftap
JugoslavDujic:
HTH
Jugoslav
I tried both
works fine.
Thank you very much.
Frank
