29649 Discussions
CreateWindow does not yield a handle nor an errorcode
Paul_Felz
Hi there,
in my prog I place a number of windows on my screen. For all except one everything works fine, but for the last one CreateWindow neither returns a handle nor an error code. See this excerpt here:
character*30 :: ccDatenfensterClass = 'DatenfensterClass'C
character*30 :: ccKartenfensterClass = 'KartenfensterClass'C
character*30 :: ccKontrollfensterClass = 'KontrollfensterClass'C
character*30 :: ccStatusfensterClass = 'StatusfensterClass'C
cWindowClass = ccDatenFensterClass
tWndClass%style = ior(CS_HREDRAW, CS_VREDRAW)
tWndClass%lpfnWndProc = loc(DatenWndProc)
tWndClass%cbClsExtra = 0
tWndClass%cbWndExtra = 0
tWndClass%hInstance = hhInstance
tWndClass%hIcon = NULL
tWndClass%hCursor = LoadCursor (NULL, IDC_ARROW)
tWndClass%hbrBackground = GetStockObject (WHITE_BRUSH)
tWndClass%lpszMenuName = NULL
tWndClass%lpszClassName = loc (cWindowClass)
iRslt = RegisterClass (tWndClass)
!   Mitte Oben: "Kartenfenster"
cWindowClass = ccKartenfensterClass
tWndClass.lpfnWndProc = loc (KartenWndProc)
tWndClass.lpszClassName = loc (CWindowClass)
!   Rechte Seite : "Kontrollfenster"
cWindowClass = ccKontrollfensterClass
tWndClass.lpfnWndProc = loc (KontrollWndProc)
!   Unterer Bereich : "Statusfenster"
cWindowClass = ccStatusfensterClass
tWndClass.lpfnWndProc = loc (StatusWndProc)
!           Einrichten des Kontrollfensters
            iKontrollTop = 0
            iKontrollWidth = (iWinWidth - iKarteWidth) / 2
            iKontrollHeight = iWinHeight / 2
            iKontrollLeft = iWinWidth - iKontrollWidth
            iStyle = ior (WS_CHILDWINDOW, WS_VISIBLE)                               ! Einrichten als ChildWindow
            iiWindowCount = iiWindowCount + 1
            iiKontrollHandle = CreateWindow (ccKontrollFensterClass,       &
                                ''C,                                    &
                                iStyle,                                 &
                                iKontrollLeft,                          &
                                iKontrollTop,                           &
                                iKontrollWidth,                         &
                                iKontrollHeight,                        &
                                hWnd,                                   &
                                iiWindowCount,                          &
                                hhInstance,                             &
                                NULL)
            print *,' iiKontrollHandle = ', iiKontrollHandle
            iRslt = ShowWindow(iiKontrollHandle, SW_SHOWNORMAL)
            iRslt = UpdateWindow (iiKontrollHandle)
!           Einrichten des Statusfensters
            iStatusTop = iWinHeight / 2
            iStatusWidth = (iWinWidth - iKarteWidth) / 2
            iStatusHeight = iWinHeight / 2
            iStatusLeft = iWinWidth - iStatusWidth
            iiStatusHandle = CreateWindow (ccStatusFensterClass,        &
                                ''C,                                    &
                                iStyle,                                 &
                                iStatusLeft,                            &
                                iStatusTop,                             &
                                iStatusWidth,                           &
                                iStatusHeight,                          &
                                hWnd,                                   &
                                iiWindowCount,                          &
                                hhInstance,                             &
                                NULL)
            iRslt = GetLastError ()
            print *,' LastError = ', iRslt
            print *,' iiStatusHandle = ', iiStatusHandle
            iRslt = ShowWindow(iiStatusHandle, SW_SHOWNORMAL)
            iRslt = UpdateWindow (iiStatusHandle)
The prints in line #104 and #105 both yield zero while the window before that ("Kontrollfenster") works just fine. The debugger shows all parameters as they are expected to be.
Any Idea on where to start to pinpoint this bug?
Cheers
PF
Paul_Felz
Got it!
This is not an issue with CreateWindow but with the windows procedure attached to the window to be created.
It happens, when the call to DefWindowProc is not performed for unprocessed messages. I had this call in the wrong line.
Problem solved.
Cheers
PF
Steve_Lionel
CreateWindow returns something - what is it? Zero?
Paul_Felz
Yes. It returns 0.  See attched screenshot of the print to screen.
PF
Paul_Felz
Got it!
Problem solved.
Cheers
PF
