29619 Discussions
Creating a program with a DLL: odd problem with MSVCR90.DLL
Arjen_Markus
I was experimenting with data in a DLL and ran into an odd problem with MSVCR90.DLL.
Here is my program:
! getdatadll.f90 --
! Get data from a DLL
program getdatadll
use datadll
implicit none
call initdata
write(*,*) array
end program getdatadll
and themodulethat is put intoa DLL:
! datadll.f90 --
! Define a module with data - the module is part of a DLL
module datadll
implicit none
real, dimension(10) :: array
!dec$ attributes dllexport:: array
contains
subroutine initdata
!dec$ attributes dllexport:: initdata
call random_number( array )
end subroutine initdata
end module datadll
Now I compile the code with the following commands from a DOS-box (I did not want
to set up a solution and project - too much work for this small program):
ifort /dll datadll.f90
ifort getdatadll.f90 datadll.lib
All is successful, but when I run the program it complains about not being able to find
MSVCR90.DLL.
The platform:
- Windows XP
- Intel Fortran, version 11.1
- I started the DOS-box using the Start menu entry "Fortran Build Environment for applications running on IA-32"
If I compile the program using
ifort getdatadll.f90 datadll.f90
the resulting executable works fine - there is no dependency on MSVCR90.DLL then.
Any idea how to solve this? (My system contains at least two versions of said DLL)
Arjen
Stephen_D_Intel
Hi Arjen,
Try this command to build your executable:
ifort /MD getdatadll.f90 datadll.lib
The /MD option tells the linker to search for unresolved references in
a multithreaded, dynamic-link run-time library. It looks like the dll
build is using different library defaults than the executable build.
Steve D.
Intel Developer Support
Arjen_Markus
Hi Steve,
yes, that does the trick! I probably should have thought of it myself, but recent, unpleasant experiences with MSVCR90.DLL and its cousins made me think that it had to do with similar nastinesses - rather than these run-time library options.
Arjen
