Creating file name strings
Mohammadjafar_S_
Hi All,
I'm trying to create numerous files in a directory with a do loop using the command open. I don't exactly know how I'm supposed to take care of the names of the files. Since I can only type a single string in the file="..." section of the open command
Any help would be highly appreciated
JVanB
Valued Contributor II
program P
   implicit none
   integer n
   character(20) filename
   do n = 1, 10
      write(filename,'(a,i0,a)') 'file',n,'.txt'
      open(10,file=filename,status='replace')
      write(10,*) 'This is file number', filename
      close(10)
   end do
end program P
Output:
type file*.txt
file1.txt
 This is file numberfile1.txt
file10.txt
 This is file numberfile10.txt
file2.txt
 This is file numberfile2.txt
file3.txt
 This is file numberfile3.txt
file4.txt
 This is file numberfile4.txt
file5.txt
 This is file numberfile5.txt
file6.txt
 This is file numberfile6.txt
file7.txt
 This is file numberfile7.txt
file8.txt
 This is file numberfile8.txt
file9.txt
 This is file numberfile9.txt
dboggs
Although it may LOOK like you can only type a single string, if you read the documentation carefully you can use a single string variable as well. Then, you have all the power of Fortran available to construct the needed characters in the string variable. The response above illustrates a specific example of this technique. You can also do some of the string construction "in place,", e.g. FILE = 'str1' // 'str2' // '.ext'.
