Cube Root Error
Frank_M
    integer(4)                                  :: i                ! a counter
    real(8),    dimension(pdlen)                :: tmp1             ! temp array for calculating
    real(8),    dimension(pdlen)                :: tmp2             ! temp array for calculating
    <bla, bla bla >
    tmp1 = ABS(tmp2)
    do i = 1, pdlen
        skew(i) = tmp1(i)**(1/3)
    end do
   In the above code skew is being returned as an array of 1.0
   The values in tmp1 are small, but SQRT(tmp1) returns the correct answers.
  What am I doing wrong here?
Jacob_Williams
New Contributor III
The correct and portable way is to use a function like this (will give the real solution with the correct sign).
!cube root : real solution
pure function cube_root(x) result(y)
    use, intrinsic :: iso_fortran_env, only: wp => real64  !double precision
    implicit none
    real(wp),intent(in) :: x
    real(wp) :: y
    real(wp),parameter :: one_third = 1.0_wp / 3.0_wp
    y = sign( abs(x) ** one_third , x )
end function cube_root
mecej4
1/3 = 0, according to the rules of integer arithmetic.
Frank_M
 do i = 1, pdlen
        skew(i) = tmp1(i)**DBLE(1/3)
    end do
Changed it to the above, it still returns 1.0
Frank_M
     Lacking a CBRT() function, is there any way short of  Newton-Raphson of taking a cube root in Intel fortran?
Frank_M
Never mind.
I found the error.
missing a dam dot.
mecej4
If you replace (1/3) with (1./3) or (1/3.) or (1./3.), the expression will be evaluated in single-precision (24 bits). You can make the expression to come out in double precision by writing 'd0' after the decimal point, or by writing dble(1)/3, etc.
Jacob_Williams
New Contributor III
    implicit none
    real(wp) :: y
Frank_M
Yeah thanks for the help.
That final bit of code looks like this:
    tmp1 = ABS(tmp2)
    do i = 1, pdlen
        skew(i) = tmp1(i)**(1/3.0_8)
        skew(i) = SIGN(skew(i),tmp2(i))
    end do
The real long term solution is to start wearing my glasses.
jimdempseyatthecove
Ah, unlike experience, that problem tends to get worse with age.
Jim Dempsey
Jacob_Williams
New Contributor III
FYI: note that if you replace "pure" in my cube_root function with "pure elemental", all your code can be replaced with:
skew = cube_root(tmp2)
No need for the loop and temporary variable.
TimP
The examples given in this thread, when vectorized, will call the library cube root function which may be expected to use Newton iterations.  When not optimized, **(1/3.) would be expected to involve log() and exp().  The underlying library functions might be expected to be the same with Intel Fortran and C++.  If you wish, you could call the cbrt function via C interop, but this would miss opportunities for optimization.
