DEBUG info
pierangelo
Can anyone tell me how I can display the value of a variable defined in a module and used in a function?
What is the syntax for adding a variable like this to the Visual Studio 2022 Watch window?
use nlinfo, only: tend
jimdempseyatthecove
try watching
nlinfo::tend
Jim Dempsey
TiborKibedi1
It seems this method stopped working possible late last year?. Here is a screen dump. Am I missing something?
It is rather frustrating to develop codes without the VS nice debugging function. Searching the forum I could not recall any encourigment from the Intel people that the problem will be resolved.
Tibor
andrew_4619
The module::var syntax works fine with me for all intel versions. I suggest your install may be broken.
TiborKibedi1
Thanks for the advice. I already tried to reinstall VS22, OneApi Base Kit & Intel HPC, but it did not help. However I just reinstalled again. Installing the OnaApi Base Kit I selected not too integrate it into VS22. VS 22 was integrated during Intel HPC. This time debugging works using the module::var syntax.
Tibor
