I'm at a loss with this issue.
I was running CVF 6.6 with no problem until I installed MS Visual Studio6.
I kept getting the DFDEV.exe application error when trying to compile.
I ungraded to MS Visual Studio.net - no luck
I installed all CVF updates - no luck.
Uninstalled MS VS6 VS.net - no luck
Uninstalled and reinstalled CVF - no luck
Deleted all files except *.for and tried to recompile - no luck
I uninstalled and reinstalled and deleted files several times and can't seem to resolve this error. Is there anyway to clean the registry?
I have this exact same problem on 3 machines using Windows 2000 and XP.
Hard to tell what is going on, but it might well be a registry problem -- registry keys are seldom uninstalled.
Did you try logging in as a different/new user? If there's no problem with that, try deleting HKCU/Software/Microsoft/DevStudio/6.0 key first, run Per-user setup from CVF program group and try (itwon't doharm except for customizations you might have made in VS).
If other user doesn't work, and/or the problem persists, delete also HKLM/Software/Microsoft/DevStudio/6.0, but it will probably require reinstallation. Make sure to install VS6 Service pack 5.
Hope this helps.
Jugoslav
