DLL is not produced.
fbalderasintel
I am Compiling with Intel Visual Fortran 11.0.075 [Intel 64] on Vista, VS 2008
Very simple Fortran code,gets no compile errors and does produce an ".obj" file yet there is no
DLL.
This used to work last November since I have a DLL from that time. I tried to modify
the DLL and got this surprise. I dont believe I've changed anything.
I've attached the BuildLog in case that is of use.
Appreciate your help.
fbalderasintel
My apologies, this was my error. My properties are sending the results (the lib) to another path.
The name of the other path is so similar that I overlooked it.
There is no issue here.
Felix
