29647 Discussions
DLLEXPORT for derived type constructor
DataScientist
Valued Contributor I
Suppose we have a derived type
module this_mod
    type :: this_type
        integer :: foo
    contains
        procedure :: bar
    end type this_type
    interface this_type
        module procedure :: constructThis
    end interface this_type
contains
    function constructThis() result(This)
        !DEC$ ATTRIBUTES DLLEXPORT :: constructThis
        type(this_type) :: This
    end function constructThis
end module this_mod
Is this a proper way to export the constructor of this_type? or should the exported name be the same as the derived type's name this_type?
FortranFan
A. King wrote:
.. or should the exported name be the same as the derived type's name this_type?
You should be able to use ALIASing facility with !DIR$ ATTRIBUTES to export the name of your choice, otherwise it must be the name of the procedure plus you may need decorations depending on the calling conventions in effect (e.g., STDCALL).
Steve_Lionel
The way you did it is correct.
