DLLs and Common block
moncef
I used Help files in IVF, "Coding Requirements for Sharing Data in DLLs", "Exporting and Importing Common Block Data", where example of appropriate DLLEXPORT directive is included and described. When I create a dll and I put common blocks that I want to be linked to the same common block in my exe program, the common block information does not pass from the exe to the dll.
How can I declare common block in both the main exe and any dll and having the information passing?
The code source of the DLL is:
subroutine Seta
use user32
use kernel32
!DEC$ ATTRIBUTES STDCALL, REFERENCE,ALIAS :"Seta":: Seta
!DEC$ ATTRIBUTES DLLEXPORT:: Seta, /X/
implicit none
common /X/C,B,A
real C,B,A
A=A+1
B=B+1
return
end subroutine Seta
The subroutine in the main program that uses the DLL is:
subroutine test
use user32
use kernel32
implicit none
pointer (p_seta, seta)
integer(HANDLE) :: dll_handle
integer(BOOL) :: free_status
integer i
real AP
common /X/C,B,A
real C,B,A
Interface
subroutine Seta
!DEC$ ATTRIBUTES DLLIMPORT:: Seta, /X/
implicit none
common /X/C,B,A
real C,B,A
end subroutine Seta
end interface
dll_handle = LoadLibrary ("DLL_a.dll"C)
! Check for errors
if (dll_handle == NULL) then
! Failure
stop
end if
p_seta = GetProcAddress (dll_handle, "Seta"C)
if (p_Seta == NULL) then
! Failure
stop
end if
! Now call the function
call seta ! the value of A in the DLL is 1
Ap=A ! the value of A in the subroutine test is 0 so Ap=0
free_status = freelibrary(p_seta)
end subroutine Test
If you have a solution, pelase send me a simple example.
thanks in advance
anthonyrichards
New Contributor III
Clearly it does not work because, by switching to LoadLibrary and GetProc Address,you have deviated from the recommended method of linking COMMON in a DLL to COMMON in an .EXE. Normally, you would add the DLL_A.LIB file to your .EXE that wants to link to your DLL_A.DLL library. That way, the locations (addresses)of the symbols Seta and X are properly generated and they are propeerly linked.
If you replace
subroutine test
use user32
use kernel32
implicit none
integer i
real AP
common /X/C,B,A
real C,B,A
Interface
subroutine Seta
implicit none
common /X/C,B,A
real C,B,A
end subroutine Seta
end interface
with
subroutine test
!DEC$ ATTRIBUTES DLLIMPORT:: /X/
!DEC$ ATTRIBUTES DLLIMPORT,ALIAS :"Seta":: Seta
use user32
use kernel32
implicit none
! pointer (p_seta, seta) ! i.e. forget the pointer, use the location of SETA that the linker generates from the DLL_a.LIB file
integer p_seta
integer i
real AP
common /X/C,B,A
real C,B,A
Interface
subroutine Seta
end subroutine Seta
end interface
a=1.1111E+00
b=2.2222E+00
C=3.3333E+00
You will find it works. you should add the before and after print commands that you have omitted from thesample codeas well, to confirm what is happening.
moncef
Quoting - anthonyrichards
If you replace
subroutine test
use user32
use kernel32
implicit none
integer i
real AP
common /X/C,B,A
real C,B,A
Interface
subroutine Seta
implicit none
common /X/C,B,A
real C,B,A
end subroutine Seta
end interface
with
subroutine test
use user32
use kernel32
implicit none
integer p_seta
integer i
real AP
common /X/C,B,A
real C,B,A
Interface
subroutine Seta
end subroutine Seta
end interface
a=1.1111E+00
b=2.2222E+00
C=3.3333E+00
moncef
Quoting - moncef
when icarry out the modifications which you proposed and I compile my main programm I obtains Error LNK2019 : unresolved external symbol seta referenced in function _Test
anthonyrichards
New Contributor III
Quoting - moncef
You must add the DLL_A.LIB list of exported functions to your Test project so that it can be used by the Test program to locate the necessary imported symbols. You must also ensure that the DLL can be found by the Test.EXE program, so copy it to the Test.EXE folder.
Also, I have found that with the code I have supplied, if you replace
with
pointer (p_Otherseta, Otherseta)
and replace p_seta with p_Otherseta in your code, and also replace
dll_handle = LoadLibrary ("DLL_A.dll"C)
with
dll_handle = GetModuleHandle ("DLLA.dll"C)
and replace
call seta
with
call Otherseta
you will find that it works. This is because, having supplied and included the DLL_A.LIB when building the Test.EXE projeect, the .EXE has all the information it needs to to link the DLL_A.DLL at load time and during this process, as a final step after calling the DLL entry point, quote
"Finally, the system modifies the code of the process to provide starting addresses for the referenced DLL functions" unquote. I think that this step is what is missing for the common block /X/ when you use run-time linking using LoadLibrary, so I think that the address of the common block is then not correctly mapped to the process's address space. GetModuleHandle is used to get the handle to a DLL that is already loaded.
moncef
How Can I add the DLL_A.LIB list of exported functions to my Test project?
anthonyrichards
New Contributor III
Quoting - moncef
Are you using Intel Visual Fortran?
If you are, I think this is what you do:
In your solution,
1. Create two projects, each containing the source files of a single language. The project that contains the main program should be made an executable project and the other astatic or dynamic-linklibrary project.
2. Right-click the executable project and select Dependencies to set the executable project as dependent on the library project.
3.Right-click on the executable project and select Set as Startup Project so that you can build it and debug.
moncef
Ihave carried out the modifications which you proposed. When I debug the main programm and when I execute the line code : DLL_handle=loadlibrary ("DDL_A") of DLL_handle= GetModuleHandle("DDL_A") Ireceive this error Message :DFORRTD.DLL not Found.
I checked in the repertory C:Windowssystem32: The file is well.
anthonyrichards
New Contributor III
Quoting - moncef
DFORRTD.DLL is a CVF DLL, so you have got hold of the wrong DLL, one that you built with CVF, I think.
moncef
You can create as many folders as you want. These are for your convenience and are not visible to others.
I found the solution to ovoid this error message. It consists of:
For the DLL :
1.in project setting => FORTRAN=>Librairies => Fortran Libraries=> Reentrancy Support : select threaded
2.in project setting => FORTRAN=>Librairies => Fortran Libraries=>Use-run-timeLibrary :Multi-threaded DLL
3.in project setting => FORTRAN=>Librairies => Other LibraryOptions:Enable Use Common Windows librairies
For theMainproject :
However, the problem persiste : the common block information does not pass from the exe to the dll.
anthonyrichards
New Contributor III
I have already posted a solution above that avoids the LoadLibrary and GetProcAddress method that clearly fails to work in your case.
moncef
it is not a problem inherent to use of LoadLibrary instead of GetProcAddress but a problem of compilation option. When one uses a DLLcontaining Dialogswith an MDI project, one should not use directive compilation REFERENCEin the DLL's dialog callback function. Instead of :
!DEC$ ATTRIBUTES STDCALL,REFERENCE, ALIAS :"Function ":: Function
One should use
!DEC$ ATTRIBUTES STDCALL, ALIAS :"Function ":: Function
It was that the solution to my problem. Thanks for having tried to help me.
Jugoslav_Dujic
Valued Contributor II
Quoting - moncef
That's not quite accurate. One should never use reference arguments for a Window procedure or Dialog procedure. You don't have REFERENCE for AboutDlgProc or MainWndProc either.
The callback functions, generally, must have the prototype that is pre-specified by the library in question (for example, in DFLOGM callbacks should be subroutine(Type(Dialog), integer, integer)). Unfortunately, if you miss that, compiler is seldom able to catch the error in compile-time, and you get strange run-time errors.
moncef
Quoting - Jugoslav Dujic
thanks for having to specify it well.
