29378 Discussions
DO LOOP with an upper limit smaller than the lower limit and with a positive step
Guillaume_De_Nayer
I have a very simple question: What should a FORTRAN compiler do with a DO LOOP with an upper limit smaller than the lower limit and with a positive step?
I wrote a small code
       program test_loop_1_0
       integer :: i,imax
       imax=0
       call loop(imax)
       end program
c---------------------------
       subroutine loop(imax)
       integer :: i,imax
       do i=1,imax
         PRINT*,"DBG",i
       enddo
       end subroutine loop
This code compiled with ifort shows that a DO i=1,0 ENDDO produces no iteration. Is this behavior written in the FORTRAN standards?
Thx a lot,
Best regards
Guillaume
Xiaoping_D_Intel
Yes. it is the behavior defined in the fortran standard. For example, according to F2003 standard "8.1.6.4.1 Loop initiation" the loop iteration count of your code will be zero, then according to "8.1.6.4.2 The execution cycle" if the iteration count is zero the loop will terminate.
It is also written in Intel Fortran Compiler documentation at https://software.intel.com/en-us/node/579912
Xiaoping Duan
Intel Customer Support
Xiaoping_D_Intel
Xiaoping Duan
Guillaume_De_Nayer
Thx a lot for your quick reply!
TimP
This behavior has been required since the Fortran 77 standard.  The original Fortran 66 standard didn't define trip count in this situation, although the most widely used compilers had the one-trip behavior, and programs were written frequently on that assumption.
