DO construct IVF vs. CVF
reidar_tyssen
The do construct
DO I=1,ISTOP,ISTEP
ENDDO
is expecteed to do to a number of loops given by:
MAX=(ISTOP-ISTART+STEP)/ISTEP
For the case ISTOP =0,ISTEP=1, MAX = (0-1+1)/1 = 0
In my code used to be compiled by CVF, this worked as presumed,
but with IVF the loop will be executed once. Why?
Is there any compiler switch to be set to avoid this?
Reidar
aagaard
Default, should be as you expect. But there exist an compiler option to control if old F66 compability (always one pass through the loop) should be enforced.
I have copied in the compiler help.
Allan
onetrip, Qonetrip
Tells the compiler to follow the FORTRAN 66 Standard and execute DO loops at least once.
IDE Equivalent
None
Architectures
IA-32 architecture, Intel 64 architecture, IA-64 architecture
Syntax
Linux and Mac OS X: -onetrip
Windows: /Qonetrip
Arguments
None
Default
OFF The compiler applies the current Fortran Standard semantics, which allows zero-trip DO loops.
Description
This option tells the compiler to follow the FORTRAN 66 Standard and execute DO loops at least once.
Alternate Options
Linux and Mac OS X: -1
Windows: /1
I would not expect this to behave differently unless, as noted, you have set the /f66 switch.
TimP
If you have an example where the current compiler doesn't follow the standard, please file a bug report. As the previous answer pointed out, the options -1 -onetrip are intended to over-ride the standard.
Minor quibble: Fortran 66 did not specify that loops should be executed at least once. That was an extension implemented by certain compilers, not always reliably. The form later adopted by f77 was already implemented successfully by certain compilers.
reidar_tyssen
As advised, the solution was to select Project from the menu, then
MyProject Property Pages -> Fortran -> Language and set the
Enable Fortran 66 semantics switch to No
My DO-loops are now running as usual..
Thanks to all of you!
Best regards
Reidarsmiley [:-)]
