29653 Discussions
Data in Array Constructor using multiplier has error
Ken_B_1
Can anyone help? I cannot get the array constructor data values to compile when using a multiplier on a constant.
This is an f77 conversion. Using MS VS 2003 and Intel V9.
The array used to look like:
      DATA ASTP1/0.,20.,40.,3*0.0/
I believed it should be like:
 Real, Parameter :: ASTP1(6) = (/0.,20.,40.,3*0.0/)
I also tried others  below that also did not work
 Real, Parameter :: ASTP1(6) = [0.,20.,40.,3*0.0]
 Real, Parameter :: ASTP1(6) = [/0.,20.,40.,3*0.0/]
The issue is there are some arrays with 80*0..
That would be alot to do by hand.
Thanks Ken
FortranFan
Are you trying to set the last 3 values to zero?
program p
   integer :: i
   real, parameter :: ASTP1(6) = [ 0., 20., 40., [(0.0, i=1,3)] ]
   print *, " ASTP1 = ", ASTP1
   stop
end program p
  ASTP1 =    0.00000000       20.0000000       40.0000000       0.00000000
 0.00000000       0.00000000
Ken_B_1
Thank you. That can work. But I wonder is the 3*0. operation no longer applicable?
FortranFan
By "3*0. operation", I assume you mean the repeat operation where 3 successive elements are assigned a specific value.  You may want to look into the Fortran language standard (https://software.intel.com/en-us/node/581560) for more detail, but I believe such repeat syntax is restricted to DATA statements and perhaps in NAMELIST I/O processing as well.
NotThatItMatters
Yes, the repeat syntax is valid for DATA statements, reference https://software.intel.com/en-us/node/580482, but I think that is the only place it is allowed.  Probably something for the deep dark past when I was learning the language.
