Data type when doing ** operation
onkelhotte
New Contributor II
Hi there,
I was wondering what data type should I use when I do a ** operation.
Is that fromcompiler point of view a difference when I calculate real**integer or should I do real**real?
For example 2.5**4 or 2.5**4. ?
Markus
Les_Neilson
Valued Contributor II
Quoting - onkelhotte
Hi there,
Markus
I believe integer exponentiation (where known)is better because of optimization eg (from the help) M=J**2 is optimized to M=J*J
Les
rase
I think it is good practice to write always a=b*b instead of a=b**2 or a=b*b*b instead of a=b**3, if possible, of course. Even if the compiler optimizes the exponentation with integers I prefer to control the optimization.
I agree with Les. Use an integer exponent if it is integer-valued.
TimP
2.5**4 would likely be evaluated as (2.5*2.5)*(2.5*2.5). 2.5**4. might be evaluated as something resembling exp(4.*log(2.5)), or it might be evaluated the same as 2.5**4
The integer exponent is certain to be at least as efficient and accurate as the real exponent. In this case, the result with the integer exponent would be exact, while that is not guaranteed with the real exponent.
If you want to be certain of a specific order of evaluation, such as ((2.5*2.5)*2.5)*2.5, you must write it out with parentheses, and, with ifort, include the option /assume:protect_parens. This prevents optimization to a potentially faster or slightly more accurate version. I don't know of any good reason to avoid the integer exponentiation.
