Debugger error for BLOCK / END BLOCK variable.
andrew_4619
Consider
Program bloky
    implicit none
    real  ::  t(2)
    t = 1.0
    print *, t
    block
        real :: t((2)
        t = 2.0
    end block
    print *, t
end program
The Fortran works OK but the debugger thinks t is [2.0, 2.0] after the end block. Also if t was not declared outside the block the debugger still things it is valid both before and after the block. ( VS2013 Upd 5, Fortran XE2017 Upd 4)
andrew_4619
Additionally the size of t is redefined by the definition in the block so if it was shorter part if the array is then not accessible to the debugger or if it was longer the debugger is presumably looking at some junk location?
Kevin_D_Intel
I created a complete reproducer and submitted this to our Debugger developers.
(Internal tracking id: DEBGGR-3091)
andrew_4619
thanks, I would guess the issues all have the same root cause.
