公告
Debugger one line off after #include
uha
新手
1,095 次查看
I hit an issue with the debugger - it gets confused about the line the source is in:
I know this happens  when your build/pdb is out of date, this  is not the case here. Instead it is related to a somewhat weird combination of #include (preprocessor) and include (Fortran).
To reproduce I have 4 files: 2 include files, one module and a main:
SomeFile.fi:
integer, parameter :: someval = 88
OtherFile.fi:
!#DEFINE BLA_BLA
#IF .NOT. DEFINED (BLA_BLA)
#DEFINE MyFun(a, b, c) .true.
#ELSE
      USE, INTRINSIC :: ISO_C_BINDING, ONLY: C_LOC
#ENDIF
TestInclude.f90 (do not remove the empty line 14 for clarity):
module MTestInclude
#include "OtherFile.fi"
#IF DEFINED (SIGNAL_MEM_ARRS)
  use NonExistantModule
#ENDIF
  implicit none
  save
  contains
subroutine test()
  include "SomeFile.fi"
  write(*,*) someval
end subroutine test
end module MTestInclude
Console1.f90:
program main
  use MTestInclude
  call test()
end program main
It does not only offset the debugger in the function with the include, but also for other functions defined after that one in the same file. Interestingly it seems you need the combination of #include and include to break it.
So for me the simple workaround is to include "OtherFile.fi" instead of #include "OtherFile.fi", just thought it might be of interest. Or maybe there is something actually wrong with the #include version?
0 项奖励
2 回复数
jimdempseyatthecove
名誉分销商 III
1,052 次查看
FWIW I use fpp and #include extensively in my solution, but I do not use "include". I do not have a line positioning error.
Note, if you are compiling with any optimizations enabled, you can(may) see such behavior.
Jim Dempsey
0 项奖励
uha
新手
998 次查看
Thanks Jim. This is in a Debug build with no optimizations. But good point about only using #include: Another way to get it to work as it should.
0 项奖励
回复
