Debugging Error Message
boloke
Dear All
I'm trying to run a programcreated in 2001using fortran 77 (to solve flow problems), there is no error in the code because when I compliled it I did not receive a "Build error" but when I tried to run, I received the following error message: " debugflow.exe is not a valid Win32 application".
I have tried to solve this prolem but in vain. I will appreciate if anyone could help.
Thanks in advance.
John Boloke.
jimdempseyatthecove
Check your options. In particular, are you generating a 64-bit .EXE file?
Jim Dempsey
boloke
Many thanks for your reply.
