29657 Discussions
Debugging IVF - 'There is no source code available for the current location'
Deleted_U_Intel
i habe the following problem:
While Debugging with IVF8.0 and VS.Net 2003 i get at some line the error 'There is no source code available for the current location'.
IE at this line of code:
variab1 = variab2 - 1.0
!variab2 is a referenced constant imported from a module by 'use' command
!variab1 is a local variable
Please report this problem to Intel Premier Support and be sure to attach a complete example that reproduces the problem. I will note that if you have enabled optimization, such messages can be expected.
