29642 Discussions
Debugging Problem - Undefined Host Data
pjh_gn
When I run my Win32 Fortran application in debug, variables defined in the module header (host associated) are not visible in contained module subprograms. The same problem for host associated variables in internal sub-programs. When I try to watch the variable I get an "undefined variable" message.I have turned off optimisation and set debugging level to full. Have I missed some other debug switch or is this a feature?
It's a limitation. For now, you can type in modname::varname in the QuickWatch window.
pjh_gn
That's great, thanks for the work-around, Steve.
