29618 Discussions
Debugging and module's global vars scope
matteo_massaro
I've got a quite annoying problem in debugging fortran projects with Visual Studio 2005. What happens is that during debugging I can't scope any module's global variable (scope window says 'Undefined Variable')! I don't know if it's related to the Visual Studio setup or whatelse but I'm constrained to assign module's global vars to some local vars and scope the local vars!
How can I solve this?
onkelhotte
New Contributor II
Quoting - matteo massaro
Update to a newer version of IVF.
Ive had the same problem with 10.1.025, but now I use 11.0.072 and now is shows thevalue.
When you cant update, use this workaround.As name use
moduleName::varname instead of varname
Markus
matteo_massaro
Quoting - onkelhotte
Markus
Actually my module global var is defined as
TYPE(myType), PRIVATE :: var
I've tried with both
TYPE(myType), PRIVATE :: Modulename::var
TYPE(myType), PRIVATE , Modulename::var
but syntax error occurs. What's the correct syntax for that?
onkelhotte
New Contributor II
You have use modulename::varnamein the VS debugger. In my case, I have the module sharedVariables and real*4 runtime as a variable. This works with your type declaration as well (bramme is a type I declared myself).
Markus
