Debugging in v15 beta
Simon_Geard
Is this the right place to ask about debugging in the v15 beta product? I've tried premier support but it says the product is no longer supported.
Well, the beta is closed now, as we prepare for release, but you can ask here, sure.
Simon_Geard
Thanks, this question is about the Linux version.
As far as I can see there is no longer a separate debugger. So I built a small application with the -debug switch and tried using gdb. Setting and using break-points worked okay but when I try printing the value of a variable the result is a segmentation fault. Is there a special switch combination I need to use to get gdb to work properly?
No, you're not supposed to need any special option. Please provide a test case we can look at. You can do it through Intel Premier Support selecting the non-Beta product - just be sure to indicate that you're using the beta.
Simon_Geard
Thanks. I have reported it as issue 6000061409
