Debugging the crash
Vladimir_P_2
I was wondering if someone could suggest an approach to debugging / finding a problem.
Setup (note two versions of Fortran):
  • Ubuntu 14.04.3
  • Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.5.223 Build 20150805
  • Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 12.0.0.084 Build 20101006
  • Piece of software, which is somewhat large
Usage:
  1. Compile software using ifort 12.0.0.084 with optimization on (-O3 and/or O2)
  2. Compile software using ifort 15.0.5.223 with optimization on (-O3 and/or O2)
  3. Compile software using ifort 15.0.5.223 with debug options (-check all -warn all -warn notruncated_source -g -traceback -debug inline_debug_info)
Results:
1. and 3. work and produce the same results, 3. (debug) doesn't show anything significant (a few unused variables),  while 2. crashes with segfault for no apparent reason.
Note: I've updated to update 5 for 2015 (15.0.5.223) just today because I had this same problem on update 4. However, I know for a fact that I was able to compile / run the code using 15 update 4 just a couple of weeks ago. Between now and before there were some linux updates and nothing else significant that I can think of.
Was wondering if someone can suggest an approach to debugging this.
Kevin_D_Intel
For build 2, under the debugger, I'm guessing you are unable to get any sense of where the fault occurs?  Is there no call stack provided if you run build 2 under the debugger and use "backtrace"?
Have you tried build 2 with -g -traceback -O2 (explicitly)?   -g implies at least -O0 so you can override that by throwing -O2 so having the debug symbols and traceback might help get information on the fault with build 2.
Vladimir_P_2
Well, the output provided by traceback tells me where it occurs, but if, for exampe I add a write statement in front of that line - traceback points to a different location (often a comment line, etc). Similar things happen when there are memory issues when assigning array elements outside of bounds, etc. But these are usually found with -check bounds.
  • -static -g -traceback -O0  - works
  • -static -g -traceback -O1  - works
  • -static -g -traceback -O2  - does not
  • -static -g -traceback -O2 -check bounds - works (does -check bounds disable some optimizations?)
Vladimir_P_2
And another note, the -O2 that doesn't work on ubuntu, runs just fine on another machine with RHEL.
Kevin_D_Intel
Check bounds introduces additional code, https://software.intel.com/en-us/node/579521 but does not disable optimizations that I'm aware of.
Do the systems have an identical CPU?
Have you checked the default shell stack limit (ulimit -s) between the Ubuntu vs. RHEL systems?
I didn't offer this initially since it felt unrelated but maybe there's a chance it is. You can refer to Determining Root Cause of Segmentation Faults SIGSEGV or SIGBUS errors for some additional things to look into (if you haven't already).
