29648 Discussions
Debugging when using Namelist and comments with national characters ()
LeonardB
Engineers does often put comments between the namelist blocks of the input file.
When running the debug version of a program using namelist and having comments containing Swedish national characters as ,, in the comments the execution stops with the message Debug Assertion Failed!
Example, this input file makes the execution to stop unless the national characters (,,) are repaced
$NMLHEAD1 HEAD1='ABC' $END
$NMLOUT ANGO=T, STRO=T, FOTFO=T, BRGFO=T, RLDO=F,
LTRANS=T, $END
RLDO=T, skriv ut relativ utbjning
RLDO=F, skriv ut absolute utbjning
LTRANS=T, Enbart rkna matrix
LTRANS=F, utfr berkning
Material
$NMLMTR IMTR=1 EM=205E9 PNY=0.3 RHO=7700 $END
p.s. I am running IVF v 11.0.066
Thanks for reporting this. I can reproduce it and will report it to the developers to be fixed. A workaround is to change the property Fortran > Libraries > Runtime Library to "Multithreaded" from "Debug Multithreaded".
This problem is fixed in 11.1 Update 3, available now.
