Debugging with /Qopenmp
Aaron_S_1
I believe I am having the same problem that was reproted here http://software.intel.com/en-us/forums/topic/281412.
When I debug a program using the /Qopenmp flag I can't view any source. If I have breakpointss set in my code, when I begin debugging I am taken to a screen that says "source not available." I can't get any call stack information and I'm also shown "No disassembly available." I don't actually have any openMP functions or directives in my code, so when I disable the flag all of my source becomes visible again and I can move throughout the breakpoints in my code. Has anyone else experienced this? Is there a solution? Thanks in advance for any help.
SergeyKostrov
Valued Contributor II
What version / update of Intel Visual Fortran compiler do you use? >>...When I debug a program using the /Qopenmp flag I can't view any source... I'll do a verification with version 13 and let you know results.
SergeyKostrov
>>>>...When I debug a program using the /Qopenmp flag I can't view any source... >> >>I'll do a verification with version 13 and let you know results. I did not have any debugging problems when /Qopenmp was turned on.
jimdempseyatthecove
When a break point is hit inside a runtime system function or library where no sources are available, you will get this message.
Goto Debug | Windows | Breakpoints
Then delete all breakpoints using the double ball x
Do not delete them individually
Next, exit VS with save solution. Then restart VS, add your breakpoint and run.
*** Note, if you have any optimization switches set, then you may only be successful at setting breakpoints at WRITE or CALL statements that are not inlined.
Jim Dempsey
SergeyKostrov
>>...When a break point is hit inside a runtime system function or library where no sources are available... There is a statement in the initial post: >>...I can't view any source. If I have breakpointss set in my code... I could only suggest to re-build the project because it is possible that Program Database file is corrupted.
Aaron_S_1
Sergey, I'm using version 13.0.3624.2010 of the compiler with Visual Studio 2010.I appreciate you checking to see if you had the same problem.
Jim, I gave this a try without any success. I only have one breakpoint set and it is in code I wrote.
Aaron_S_1
I just discovered if I have 2 breakpoints set, one in the main program and one in a subroutine I can't view either. I removed the breakpoint in the main program and now I can view the subroutine. The original post I referenced also seemed to indicate that the main program was involved.
SergeyKostrov
>>...I just discovered if I have 2 breakpoints set, one in the main program and one in a subroutine I can't view either... Could you create a small test project which reproduces the problem? Thanks in advance.
SergeyKostrov
>>... I'm using version 13.0.3624.2010 of the compiler with Visual Studio 2010... What is Edition of VS 2010? By the way, I did my tests with Visual Studio 2008 Professional Edition. If you will be able to create a reproducer I'll repeat the test with VS 2010 Shell. Thanks.
jimdempseyatthecove
Sergey,
VS, at times, can get a breakpoint set at a position other than that of a start of a statement. Sometimes when this happens, the debugger code that synchronizes the break location with source code gets goofed up. Also, the reason for delete all break points, as one operation, is I have had personal experience of a break point being set .AND. not listed in the list of break points. The only ways I could get rid of it were: a) create a new project and copy the files (not too pleasant), and I discovered the b) route of "delete all breakpoints". This happened back with VS 2005, but it is worth the exercise to give it a try.
Jim Dempsey
